Fiberglass or plastic???
kingman
Georgia
2002 Torch Red Coupe
HI
I was reading a book devoted to corvettes and it mentioned that the C5 body was made from a new kind of plastic that is lighter and stronger then fiberglass.
This stood out in my gray matter becasue somebody mentioned that the hood of the C5 feels lighter then the C4 hood.
Also the C5 was cheaper and easier to fix then a C4 because the fenders of a C5 are bolted on.
Strange but true!
Alan
kingman said:
HI
Strange but true!
Alan
A C4 clamshell hood has 4 times the amount of material because it is so much bigger(its the hood and fenders in one piece) than the C5..thats probably why it is heavier...:upthumbs
Corvette's body has been made almost entirely of SMC since 1972. SMC has had some revisions here and there but it's still SMC.
corvettecrazy said:
So if SMC considered fiberglass?
I suppose it depends on who you ask. SMC is a polyester based, fiberglass reinforced composite material produced in a sheet format and formed into shapes using compression molding. Smooth on both sides and uses no gel-coat.
