S
speedbird1229
Hi,
Since I've done some paint work in the past mainly on model cars and planes, I've decided to give a try and fix some paint damage on my Vette. It's basically a plastic model car, just life size!
I'm just going to test on some hidden areas where some chips of paint have come off.
The paint layer on the body seems to be quite thick. So, if a chip of paint comes off, it leaves quite a nice "hole" into the paint. I know that the best would be to fill the hole and leave a pimple of paint on the surface and then gently wet-sand-paper and polish it smooth. However, filling it in with just a thick coat of paint doesn't seem like the best idea. It would dry for days. I'm thinking of using some automotive filler compound (is this the right word?) and fill the holes with that first. I'm quite sure I won't be able to place the compound just into the small hole and nowhere else, hence I would like to know if the compound can be easily cleaned off from the good paint around the paint damage after having applied it to the proper location? I've only seen such compounds used on larger surfaces, not in tiny spots.
I did some testing yesterday with some hidden edges of the t-tops that had chips off (probably because they have been placed on a hard surface after taken off from the car). I've found the right color and it really seems to be ending up pretty nice - times better than damaged paint. If I could just fill the holes with something else than the paint itself, I'd be real happy and it would speed up the process remarkably.
Thanks for help!
Thanks for help!
