jose
All body coated with Epitech will need board filling before recoat and sand again prior to paint. Looking good tho and very happy with all gaps
Does this primer require any special surface treatment when used on fiberglass?
How smooth is the surface after the primer cures?
Does it need a lot of sanding?
Do you paint directly on top of this primer?
What type of paint will you be using (base cler, enamel, single stage urethane)?
I have been trying to find a product that is equivalent to your Epitech (Epotec) here in the US, but it is difficult to compare the specifications. Do you know the name of the manufacturer?
Thanks,
Charles
