61 Silver
Took the 63 out for a short test drive this evening after 1 1/2 years of restoration. Everything went well for the first drive, but it would not start after setting for about 1/2 hour. I believe that I burnt the points. I am using an original .3-OHM Delco resistor. I had the same problem with the 61 and ended up using a higher resistance resistor and it solved the problem. Now to secure a new resistor and install the new points.
Ray
Ray
