First Mod Worries
  • Thread starter Thread starter DoomDriver
D
DoomDriver
OK - My first mod is complete and works perfectly!
I installed my CAGs today. Everything went very well but I have one issue. My jack has a range of 5 1/4" to 15 " with a 2 1/4 ton capacity. Because of the 5 1/4 " start I have to drive up on home made ramps - no big deal. But to get the 2x4 wood block to protect the aluminum cross members I have to build higher ramps - again ok but...
Then I have my home made two puck jack stand holders. They work well but now I have to jack the front or back so high to get the jack stands to fit under the two pucks. I am worried as the jack is at maximum extension.
Do I get a bigger better jack or what. Advice appreciated!
I use the same as you and really don't see a problem. I do however use a piece of rubber between the jack and the crossmembers instead of a 2 x 4. I just take my time and make sure the stands are centered on the pucks, etc.
I really want a 4 post lift and then I don't have to worry about it! LOL
Save the wave :w
