fitting 1205 size mini ram to l98 heads please
sxyvet
Dandenong,victoria-Australia
1991 ZO7 coupe, 6 speed,red on red w/most options!
hi guys,
im just about to buy a 1205 size port mini ram from tpis!
any way jim @ tpis said if i want to fit this size 1205 mini ram port on my 1991 l98 heads that i would have to modify /grind the heads/valve covers to make them fit!
he mentioned about grinding about 5 cm of some where and he said that i can carefully do this with the heads on the car as long as the all the ports and every thinng is covered properely!
im confused on what needs to be done/modified here now?
can some please help with explanation/pictures please?
where,what ,how to do this please to make them fit ?
thanks
glen
bossvette
Gone but not forgotten
West Unity Ohio
I would pull the valve covers off to grind them, I am not familiar with the TPIS system but I would think they would have instructions with pictures and dimensions for the install that you could acquire.
BTW I'm not real up on metric but 5cm seems like quite a bit isn't 5cm the same as 50mm which is over an inch?
KANE
Moderator
KY
Dark Blue 1982 Trans Am(s): Polo Green 1995 MN6
hi guys,
thanks
glen
Dumb question- but what about removing the valve covers and then re-installing them... perhaps with thicker gaskets?
Ya' know... it may not be the entire length of the valve cover that needs to have material removed. Maybe it is just along the injector bosses. If so, then remove the valve covers, test fit the intake, then mark the areas that need to be ground down.
To use my aluminum valve covers on my Vette with the TPI, I had to loosen them and the reinstall them after the intake was bolted down.
sxyvet
hi there bossvette and darkshark,
thanks for your replys and help guys!
i will give what you suggested a go.
cheers
glen
