firstgear
- Joined
- Oct 11, 2003
- Messages
- 1,895
- Location
- Norwalk, Ohio
- Corvette
- 15 Z06, 01 Vert, 63 SWC & 60 ALL RED
Well....got busy today and started fitting the Myers Racing 9" rear to my 60' C1. Had to cut off a couple of pieces on the frame before getting started, as I go, I realize there is no turning back now....
At the top of the rear coil over shocks I attached them where the original ones went, but in addition to that, there was an additional support required to be welded on....I tacked it on...again, excuse my welding, I will have someone that knows how to weld make the proper welds as well as make them look GREAT!
I need to get everything tacked in so I can take the whole thing over to the fabrication shop for final welding, then back home for sand blasting and finally to work to get the frame powder coated.....
In order to get the axle correctly centered and then to stay there, there is a "panhard" rod that keeps the axle in the right place left to right on the car. As I was measuring, I realized that I needed to move the housing to the left about 3/8", but then there wouldn't be enough threads still engaged in the panhard rod. So, I stuck a piece of 3/4" plywood in there to see if that was what I needed to move out from the frame, when I get it measured up perfect, then I will get a piece of steel welded onto the bracket and then weld the bracket to the frame. In the meantime, the plywood adds a nice touch, wouldn't you say?
I am missing the sway bar from the shipment, that still needs to go on....and there are a few other odds and ends that may be missing, or in one of the boxes I got that still needs to be opened....
I think this is going to turn out just fine.....I am planning on the frame being powder coated semi gloss black and the rear housing and the 4 links and panhard rod to be powder coated silver, I have some clear coat powder that I could apply over the silver...haven't decided yet....any comments on the results so far or other ideas on the color of the powder paint?
