R
resto75
I discovered that my rag joint is loose and sloppy and needs replacement. I found that I have some play in the steering wheel and a quick look at the rag joint at first appeared to be OK. With a closer exam and a little shaking of the steering column post showed the rag joint had considerable play and it was separated at two points over the bolt holes.
I haven't attempted taking it apart yet but did find that there is a steering column coupler repair kit for fixing the problem.
Has anyone done this and can you offer any advice. I am not sure whether or not you have to move the steering column to get clearance to take it apart.
