flat spotted tires
Tallahassee, FL
none right now :(
Took the CE this moring to work... what a nice topless drive:)
I haven't driven it in a couple of weeks though, and the cold garage floor flat spotted the tires... they worked back to round (for the most part) by the time I got to work, but I am curious if there is a cheap way to get them to not flat-spot... I really don't want to buy those tire cradles, because it seems like such a waste, but the car was really rough riding this morning, and don't want to go through that either!
You did not indicate what tires you have, brand, model, etc.
Have a great day,
flatspot
I've got a solution.... Drive it more often!
Never had a problem with flat spots, except from the occasional wheel lock up or rear end slide!
vrotate
everyday vette!
Also if it really bothers you and its warm outside simply overpressure the tire 15 pounds and drive a few miles then let the excess air out. That will help as well.
(Try not to slalomn the car with 50 pounds in you'll risk busting a bead)
Red, that may help with the flat-spotting, but you should still check the air pressure in the tire when it's cold. ;)
_ken :w
I have Kuhmo's up front (new) and goodyear GSC's on the rear... driving it more always sounds good... it is tough sometimes to get it out of the garage.... I don't like driving it to work because of tree sap problems in the parking lot, and if I go out of town the weekends are shot... I was hoping someone had an idea for something home-made....
Also, i do keep my tires over-pressured anyway, (about 40psi) becuase of previous problems with outside tire wear
They also are round again, after driving around town a bit, but it was really bad this morning, I would describe the shake as being almost violent... and the way Tallahassee is set up, I don't drive very far to get anywhere, so it takes a few trips to work out the flat spots....
thanks for everyones help:)
Ken I don't read ya :confused
All I meant was when its warm outside the rubber will be softer and more willing to reshape. The pressure helps to speed the process.
Irony = Californian explaining cold weather technic to a Canadain
HEHEHEHahhahahee
:J :J
(Im joking of course)
HEHEHEHahhahahee
:J :J
That is pretty funny when you think about it....
Tire pressures should always be checked cold.
From the Tire Rack web site:
The tire pressure recommended in your vehicle's owner's manual or tire information placard is the vehicle’s recommended "cold" tire inflation pressure. This means that it should be checked in the morning before you drive more than a few miles, or before rising ambient temperatures or the sun’s radiant heat affects it.
Since air is a gas, it expands when heated and contracts when cooled. In most parts of North America, this makes fall and early winter months the most critical times to check inflation pressures...days are getting shorter...ambient temperatures are getting colder...and your tires' inflation pressure is going down!
The rule of thumb is for every 10° Fahrenheit change in air temperature, your tire's inflation pressure will change by about 1 psi (up with higher temperatures and down with lower).
In most parts of North America, the difference between average summer and winter temperatures is about -50° Fahrenheit...which results in a potential "loss" of about 5 psi as winter’s temperatures set in. And a 5 psi "loss" is enough to sacrifice handling, traction, and durability!
Additionally, the difference between cold nighttime temperatures and hot daytime temperatures in most parts of the country is about 20° Fahrenheit. This means that after setting tire pressures first thing in the morning, the vehicle’s tire pressures will be almost 2 psi higher when measured in the afternoon (if the vehicle was parked in the shade). While that is expected, the problem is when you set your vehicle’s tire pressures in the heat of the day, their cold pressures will probably be 2 psi low the following morning.
And finally, if the vehicle is parked in the sun, the sun’s radiant heat will artificially and temporarily increase tire pressures.
We put some of these theories to the test at The Tire Rack. First, we mounted two tires on wheels. We let them sit overnight to equalize and stabilize their temperatures and pressures. The following morning we set them both to 35 psi. One tire and wheel was placed in the shade while the other was placed directly in the sun. We then monitored the ambient temperatures, tire temperatures and tire pressures through the day. As the day’s temperatures went from 67° to 85° Fahrenheit, the tire that was kept in the shade went from our starting pressure of 35 psi to a high of 36.5 psi. The tire that was placed in the sun and subject to the increase in ambient temperature plus the sun’s radiant heat went from our starting pressure of 35 psi to a high of 40 psi. In both cases, if we had set our tire pressures in the afternoon under the conditions of our evaluation, they would have been between 2 and 5 psi low the following morning.
Next we evaluated the effects of heat generated by the tire’s flexing during use. We tried to eliminate the variable conditions we might encounter on the road by conducting this test using our "competition tire heat cycling service" that rolls the tires under load against the machine’s rollers to simulate real world driving. We monitored the changes in tire pressure in 5-minute intervals. The test tires were inflated to 15 psi, 20 psi, 25 psi and 30 psi. Running them all under the same load, the air pressure in all of the tires went up about 1 psi during every 5 minutes of use for the first 20 minutes of operation. Then the air pressures stabilized, typically gaining no more than 1 psi of additional pressure during the next 20 minutes. This means that even a short drive to inflate your tires will result in tires that will probably be "underinflated" by a few psi the following morning.
Add all of these together, and you can understand why the conditions in which you set your vehicle’s tire pressures are almost as important as the fact that you do set it.
It’s important to remember that your vehicle's recommended tire pressure is its "cold" tire inflation pressure. It should be checked in the morning before you drive more than a few miles, or rising ambient temperatures or sun’s radiant heat affects it.
And by the way, if you live in the North and park in an attached or heated garage you will "lose" pressure when you leave its warmth and venture into the real world outside during winter. Add 1 psi "cold" pressure tire pressure to compensate for each 10° Fahrenheit temperature difference between the temperature in the garage and outside.
_ken :w
Ahhh yayaya I knew that I thought you were well Ummm ugh.. Nevermind
LOL
:L :L :L :L
what kind of kumho's??
I just brought the 712's to be mounted this week. $108 each
did the 712's flat spot?
