Flex-fit vs reg fiberglass?
Jim B
Illinois
1974 L82 Grey coupe
I was ondering about everyones thoughts on the two types for a front bumper. Quality, and very important is ease of installation.
Thanks, Jim
K
kdlp
I replaced mine with fiberglass units from ACI.
I'd heard a few bad install stories from posters on tru-flex covers, but those were mostly from first-timers.
I think both fiberglass (buy from a reputable manufacturer) and tru-flex units are OK as are the GM urethane covers they are making now. The old urethane was subject to waviness when exposed to temperature changes.
My fiberglass covers went on after a lot of trial and error and by using the new style retainers. I went with the glass covers because I wanted to mold them into the quarter panels and fenders. (Filling in the seam between them.)
I found the easiest way to do the install was working from the center line out. I lined up the center line of the cover with the centerline of the hood, marked, drilled and worked to the outside from there. You can use a similar plan in the back by extending a (imaginary) line from the center of the fuel fill opening.
kdlp
bill81vette
Moderator
Troy,NY
1981 dark blue metallic
I used the tru-flex on my vette when the body was redone several years ago...just a matter of trial and error to get them to fit.Just bear in mind,you need to be much more careful as they do not take hits all that well!!!!!!
Jim B
Illinois
1974 L82 Grey coupe
Hey guys, thanks for your input. I'm looking for even more opinions also. The more the better! thanks
KANE
Moderator
KY
Dark Blue 1982 Trans Am(s): Polo Green 1995 MN6
Thanks, Jim
I'm going to just fork over the cash for urethane when the time comes for a new rear bumper.
I went seamless on my last C3. I liked it, but as Bill said- it doesn't take hits well!
