C
C4 Guam
Flooding Problem
Need some advise as to what could be going on with a flooding problem I'm experiencing on my 88. The car floods when the fuel pump power is connected. If I disconnect the fuel pump from the power supply the car will start right up and run fine until it runs out of fuel. If I connect the fuel pump once the car starts it stalls within in 3-4 seconds from too much fuel delivery.
So far I have changed the fuel pressure regulator and set fuel pressure to 40psi and re-set the TPS to 0.54v.
Look forward to some assistance figuring this one out.
Regards,
Fred
Regards,
Fred
