Took a peek in the Helm's for my 95 & sure'nuff the capacity is listed in the power steering repair section.froggy47 said:Thanks Rabbit. There has to be a fluid capacity that GM published somewhere. The engine oil has a dipstick too, but it has a published capacity with & without oil filter.
froggy47 said:Wow, that's all? Thanks Rabbit. The one pint for the res. is exactly right as that's what I sucked out with my new turkey baster
The 1.5 for complete system seems low to me, does it to you? There's the res, the pump, the cooler & all the hoses?
Does the ps fluid circulate thru the steering rack? I am not really sure on that.
If it's really total 1.5 pints then remove/replenish of two qts should do a pretty good job.
