joshwilson3
On my 89 I had some firewall leaks that let water run under the carpet on the floorboards. The factory foam insulation for the floorpans and tranny tunnel is ruined and needs to be replaced.
I did get some sound deadner that is supposed to go down first, then the foam insulation, then the carpet.
What are you guys using to replace the factory foam insulation? I did hear about a company that makes some foam insulation to go under their carpet, but you have to buy a whole kit for $150. As I'm just needing to do the front.
I had thought about getting it from a parts car, but that is always a gamble as it could of already had water damage. I think I've read of people getting stuff from Lowe's, but I don't know if they are using that under the factory foam insulation, or to REPLACE the factory foam insulation.
I'll also need to replace one of the drain plugs in the floorpan as well.
