Foggy daytime running lights
  • Thread starter Thread starter redrider
R
redrider
Foggy Daytime Running Lights
Both front running lights hold moisture when my 2002 z06 gets wet. Dealer tells me that is normal, the lights are not sealed and eventually they will dry. I beg to differ. What about all the others out there ??
The running lights on my 2002 hold moisture when the car gets wet. The dealer tells me this is normal and that the lights are not sealed and will eventually dry out. I beg to differ. What about all the others out there??
Redrider,This happened to me too on my 2002 z06. The dealer replaced them under warranty with no questions asked. I haven't had any further problems.
Tammy
HI there,
There are breather vents on each light assembly.
If there are droplets that are inside, after 10 mins of on time, then there is considered a problem.
Allthebest, c4c5:hb
I don't seem to have this problem with the day time running lights; but I do with the RH fog light. Anyone else out there experience this? I would appreciate some information on this if anyone else has had this problem. I just assume it is a moisture problem of some kind. Please advise if you have had this problem and let me know what I need to do.
Thanks,
Bill
