TJM
New member
- Joined
- Nov 10, 2010
- Messages
- 3
- Location
- Duluth, Georgia
- Corvette
- 1989 Smoke Gray Metallic and 1984 racer
Asking $15,000.00. This is NOT your average C4. This is a running track car that needs nothing. Can be driven by serious buyers.
Was on Track in December [ 1:45 lap times at Road Atl. ], and will be on track in March pending the sale.
All receipts, build sheets, parts list, dyno tunes and Computer files,
Pictures available.
Motor and driveline related :
· Professionally built 383Cu in ., Complete build sheet with Pn. Of ll components and dyno report
· 425 Rear wheel Hp, 485 ft torque in present form.
· 4 bolt Mains ,
· Brodix Al. Heads [ 23 degree]
· 11.5 : 1 comp.
· Fully Sequential FI
· New 650CC Bosch Injectors flowed EV14 [ FIC units ]
· LS coils [ cam and crank triggers]
· Edelbrock Al. H2O pump
· DIY Megasquirt MS3/V3.0 fuel management Fully computer controlled with integral MAP Sensor included.
· Edlebrock #29785 EFI Victor intake and #3878 Throttle Body, #3630 corrected and prep’d rails .
· All new sensors: TPS, O2 [ INNOVATE LC1 ] ,, AIC.
· Walbro 465 lph in tank running 65psi right now using E85 fuel
· All AN ethanol rated fuel and return lines.
· Aeromotive FPR bypass A1000-6
· Klushman 4706BK 100 Micron filter
· B&M Oil Cooler with electric fan for cooling.
· March matched Billet Pulleys
· Power Maters 8062,14volt one wire racing type alternator
· Hitachi 2.75 Kw Hi torque starter
· Holley 60-2 Crank trigger and hall sensor
· Canton 7 qt. RR pan and oil cooler.
· Melrose headers ceramic coated.
· Coated Y pipe to Moroso 98 Db race mufflers.
· Griffin Radiator. Twin electric fans
· ZF Black tag 6 spd.:
· Hurst Short Throw Shifter
· Ram 2511 al. flywheel
· Ram 900800 Push style Clutch [ 2,800lb. clamp , 700hp rated].
· New internal Hyd. Throw-out bearing
· 3.47:1 Dana 44.
· New Spicer universals joints throughout [all six]. Billet Oil Catch bottle
Braking:
· C5 front Calipers [ new, one session]
· Hawk Pads [ DTC 70 ] these are just marginal after one session.
· Hawk DTC7 Rear C4 pads these are just marginal after one session.
· Doug Rippie Bias spring in new Master Cylinder
· Front Brake cooling ducts
Suspension:
· New SKF front wheel hubs
· ZO7 front spring
· 30mm Front sway bar
· Z51 rear spring
· 26mm Rear sway bar.
· S Global West Del-A Lum , A-Arm bushings.
· Energy Suspension Bushing through-out
· Power Steering cooler
· 1.75:1 quick steering Rack and Pinion
· Energy Suspension Bushing [all but Bat Wing ].
· Doug Rippie Trailing arm Brackets
· Doug Rippie Camber Brackets
· Banski Adj. Toe and Camber brackets [ full adjustability of rear]
· Rippie Bilstien all around
· 17” / 18” C5 wheels w/Nitto NT - 05 17” / 18” rear
Safety related:
· 6 point SFI roll cage
· Simpson 5 point harness.
· Kirkey 47 series seat and cover.
· SAF- LT5 Fire suppression.
General:
· One of a kind cold air induction hood. Raised hood Will Clear Holley and most intakes
· Decent paint Ruby Red with Grey racing stripes.
· Grant 38 spline quick release wheel
· Tach
· Speedo
· Oil pressure [ elect]
· Oil Temp
· Volts
· Water Temp.
· Fuel pressure [ elect] .
· Mold Craft front spoiler [ green wood Aero Plus] This is not a bottom breather.
· Aluminum Pedal Bracket
· Hood pins and hood springs
[ and……. A New Holley Ultra 650cfm carb available to any masochist out there? ]
Pictures available.
· 4 bolt Mains ,
· 11.5 : 1 comp.
· 3.47:1 Dana 44.
Braking:
Suspension:
· ZO7 front spring
· Z51 rear spring
Safety related:
General:
· Tach
· Speedo
· Oil Temp
· Volts
· Water Temp.
