For you guys and gals in hot weather...
  • Thread starter Thread starter Steve Calvin
Also....whats great...actually a must have item...is the dot matrix static cling film you press on the inside portion of the targa top. www.ecklers.com part #26375. You can see thru it..but it cuts down the suns heat. I take it off in the fall & cooler months. Then come May...back on it goes
i am NOT recommending the following for a vette--i had a daily driver black ss monte carlo/t-tops with air that sorta worked-it was unbearable on a sunny day--in desparation i grabbed a rattle can of silver paint,did a quick masking job staying about 1/4'' away from glass edge, and painted the inside...took all the hurt away, not like the same car after that
concept proven
Does it act as sort of a air tunnel pulling air through the car? Seems it would have that effect.
Hot Days
I agree with FAST87 the dot matrix static cling works to cut down to the temp in the Vette and prevents a sunburned head !!!!!!!!
Steve Calvin said:
[FONT=Verdana, Arial, Helvetica] For folks in hot climates, especially if your A/C doesn't work or you don't use it. Get one of these http://www.ecklers.com/product.asp?pf%5Fid=30728&dept%5Fid=1612[/FONT][FONT=Verdana, Arial, Helvetica]They work *great*![/FONT]
Those are nice, but I respectfully ask that you check into the 1 made by
www.corvettegadgetman.com
They work really great, are less expensive and you're buying them from the man himself that manufactures them. He really stands behind his products.
I agree as well...
I've had one on my targa only LT4 for over 2 years...and that's here in Phx. It has worked so well that I've more or less given up on the thought of getting the solid top.
Need to get the hatch vent though.
