Vette/Berlina-coupe
- Joined
- Nov 18, 2002
- Messages
- 284
- Location
- southern california
- Corvette
- C3-coupe/MercedesBenz-540K replica! Racing-SB-V8!
FORSALE: -two '81-'82 Delco C3 Digital-dial Radios...
-that's right, have a couple of decent Delco/Electronic Digital-dial(modern liquid-crystal) Am/Fm/Cassette (not 8-track) later C3 Radios (last of the Delcos with dual-shafts, -the left is on/off-volume, and the right is an incremental-click rotary-action electronic tuning-knob). One is a slam-dunk installation from a C3 replete with the three impossible to find oem/aft-plugs (required if you are having to renew some of the jillion harness-wires that may have been thoughtlessly cut by Bubba's/Radio-shoppe for installation of an aftermarket-radio); -they are color-coded so just splice the matching-colors colors together and slide-over a shrink-tube, -and the wiring will be like new! The companion radio is essentially identical, but the unseen black-plastic backing-plate would need to be trimmed of the L&R-extensions used only in the '82-Cadillac it is from. As seen in the single pix below, both have separate Base & Treble -sliders, and the chrome pushbutton-presets, but their 4-piece shaft-knobs are not the original C3 small/black-plastic style (however, one set is small enough to fit into the Bezel-cones of your console-panel, -until you find correct oem-C3 knobs). Am offering as a package-deal for: $195(+ UPS-shipping); -you can left-click on my handle at upper-left here to E-mail me directly for requesting additional E-pictures if you wish...
~Bob VonHeck in sandiego calif.
