freezer with great looks!
  • Thread starter Thread starter captbane
C
captbane
Hi ya guys ! broke my 89 vette out of the winter cocoon , weather is cold but clear. Prolem is that im freezing my butt off ! I have the climate control in this car and had problems before i had alot of work done with the head gaskets ,ect. with the heat,. no matter were i set the heat or what position i use on the control , it always blows cold air! iS There a door thats not opening? I have the chip and the 160 thrmo. in this but thats not the problem is it? thanks DOUG.
yes thanks,found my book, looks like i need to pull the climate control mod and check the vac lines behind it
thanks doug c.
cold car
gmjunkie said:
1st check vac under hood ,check for air lock in heater core. "eng. work" no need to pull climate control if you dont need to!! gmjunkie!!
ok how do i check for a heater core air lock? both lines going into the firewall are warm. tx doug castner
