Front Driving Light Assembly
cfour93
Michigan
1993 Artic White Coupe
Can someone here direct me in removing the front driving and turn signal assembly? I want to clean out the front lenses i have notice that there is what appears to be a sandy color dirt/dust inside. Has anyone attempted to do this before?
Thank You - in ADV
While the assembly is "sealed" as is glued together, there are some air vents to keep moisture from condensing inside. This is probably where the dust is getting in.
To remove the unit, you have to remove the entire urethane bumper cover. There are a good number of screws and nuts all around the cover. It's sort of a PITA to do and probably not worth the effort.
My 92 is the same way.
I had a feeling this was what was involed. But thought i would ask just in case. I don't think i will under take this one. Thank you for the info....
