Johan
I just replaced a lot of stuff in the front suspension, and will need to make a front wheel alignment.
Is there a recommended initial setting to use on the upper a-arm caster/camber adjustment shims (when I put everything together, begore the alignment)?
Previous owner (bubba?) have used a total of half an inch of shims on some of the bolts, but according to the ass. manual, the maximum to use is one .12 + one .06 if i remember correct.
Will it make any sense to put these shims back?
