J
JakesVette24
Has anyone put (roller blade type bearing wheels) inside the square bumper guards.
Die grind out a part of the bumper that a 3 1/2" or 4" sleeved H.D. solid rubber wheel would fit in. Put it in with sex bolts, right where you would scar the bumpers if you when up a steep drive way or parking lot concrete stop. Mounted correctly a driveway that would have to be driven into nearly sideways, you can slowly let the wheels you just put in take the scrape away until your tires are back down. A little re-enforcement of the square tube bumper suggested.
Also a piano type hinge mounted splash guard flexes when coming out or in a driveway. No way to hold the pieces together and not have them break especially backing out and scraping. Let it flex on hinges, and stop replacing the cheap push in plastic holders.
Again just a FYI/.
Again just a FYI/.
