Front End Squeak when its Below freezing
  • Thread starter Thread starter Blade
B
Blade
When my 03 AE (with magnetic ride control) is parked outside and the temp is below freezing (no ice or snow, just cold) I have a little problem when I first crank-up and drive.
When I hit a bump in the road I get a squeaky sound from the front suspension and the car handles rough almost like the suspension and ride control are not working properly. Everything goes back to normal once the car warms up after a few miles. The feeling is similar to how the car handled before I discovered the Shock Stuffers were not removed 6-months after owning her.
Thanks,
Squeaking in Suspense.
Hi there,
Actually, I would suggest that your antisway bars are binding in the bushings.
There is a special grease that we use here in the Northeast on rubber to metal contacts.
It is a GM 'Special Lubricant' and is very reliable for fixing this type of noise and problem.
I would contact your local dealership because it is very expensive, $75 for one can.
I will try to find the part number and post it.
Allthebest, c4c5:hb
