Easy peasy! Mine popped out in a couple seconds. I can't remember if the litte plastic hook pieces are on the bottom or top but get down at eye level and you should be able to see them. On mine I was able to do it without any tools, I just pushed in and down from the bottom and then pulled the bottom out then the whole thing just pulls out from the two tabs at the top. If yours is a tight fit it may require that your insert a thin screwdriver carefully to pop the tabs loose at the bottom. Sheath the screwdriver with a chammy or something.kingman said:Hi
Next week l have to take off my front license plate filler. What's the best way to take it off without hurting the paint?
Alan
My C4 was easy a torx, 2 screws and bingo.
I guess I'm lucky mine never fell out then. They weren't there so I figured the holes underneath were for a license plate. I removed it the day I brought the car home last year - maybe the guy I bought it from had just stuck it in there after he removed his plate. I've had a plate on the front since day one. Hmph, go figure. - EricJoe Vette said:If I'm not mistaken I thought there was 2 phillips screws at the bottom gap of the filler. Use a thin screwdriver and you won't do any damage.
Eric said:I guess that settles it, I can add the missing screws to the list of brain farts the previous owner hadlike not realizing the little black thing under the fuel filler door holds the gas cap.
-Eric
kingman said:Besides two pressure points there are also two screws?
Alan
kingman said:Thanks
Alan
