T
t4bz
In addition to the rear end stuff...which I chickened out on a left to a professional...I'm going to need to replace the bushings in my front A-arms. I've pretty much decided to buy a poly set that comes with it all...ball joints, tie rod ends, bushings, idler arm, etc...and I'm thinking I'll give it a go myself. I'll probably throw on springs while I'm at it (the famous while I'm at it).
After reading the boards, though, I have a question. Is it necessary to remove the radiator? Some thought so, in order to access the upper ball joints, I guess.
Hope I don't get in over my head with this. Any other fairly inexperienced folks attempt this sort of thing?
Thanks...Travis
Thanks...Travis
