HammerDown
Silly question and I should know better but...when I usually adjust tapered wheel bearings, I usually set the nut by just the weight of my arm on a wrench. > and it's always worked fine.
BUT...by doing so this time I'm right between the slots on the castle-nut...if I go one back I've got slight up/down play in the wheel. If I go one slot tighter well...I feel it may be too tight!
Will a heated wheel bearing expand any...?
