Hello All,
Does anyone have words of wisdom regarding loosening frozen bolts?
I am attempting to replace the left rear brake caliper. I was able to remove the back caliper mount bolt with a great deal of effort, but the other mount bolt will not come loose.
I've sprayed and soaked the culprit bolt and threads with "PB Blaster" and have been struggling with this for two days. I'm using an impact driver at approx 120 psi. My Vette-owner neighbor suggested that I also use MAP gas or an acetylene torch to heat up the caliper and then strike the caliper with a hammer... and as a final resort to cut the bolt! Not sure how I would go about doing the latter... and it sounds like that option would result in big bucks in repairs (i.e., new trailing arm, etc.).
This resto project is a constant one step forward; three steps back... so ANY help is appreciated.
Thanks!
69Shark
Thanks!
69Shark
