FS: 1985 C4 Corvette HOTROD! LS Engine DBW NEW EVERYTHING!
iamc4crazy
New member
erie
Hello,
Reluctantly, after spending 2 1/2 years building this car I am forced to sell it. This is truly a one of a kind car, a must see to appreciate Car!
For sale is a 1985 5.3 litre LS Hybrid. The Engine has 950 miles on it! A Full Custom wire harness built on the car direct to the fuse box as if it came from the factory built this way. NO PLUG and Play Hack in here! Brand New: Gas Tank, Front and Rear shocks, Seat Covers, Door panels, Shift Indicator, New Window Regulators, Weather stripping, Windshield Vette-aid Cluster. The 3" all Stainless exhaust system Cost nearly $2800 from the headers back to the Mufflers. Specialy ground Cam shaft that Added 90HP to the existing 320 hp. Car is estimated to have 420HP. VERY Fast!!! I Have Nearly $20,000 Invested in the car.
PLEASE, PLEASE, no bull---t calls! Serious inquiries only as I simply don't have time. I need to make the sale of the car as swift as possible. I am in a very Dire situation and need the money more than I need my Precious Corvette. I hate to sell her, but have no choice!
ASKING PRICE IS $8,500.00 or best offer! Again serious Inquiries Only!
Either inbox me or I can be reached at
BARRY KNIGHT
CELL: 814-860-4748
I have Tons of New Parts that have not been installed that come with the car.
This was a very clean Build and this car has lots of potential. Don't let anything you read scare you off. I've worked at a GM dealership for 25 years and have owned 6 corvette and have lots of experience with these cars. I am a Man of my word and offering up all info that I have on the car. I've owned it for 4 years!
FLAWS:
The car was Painted Blue about 3 Years ago but has a few Chips out of it, a spot on the hood that needs fixed and front & rear Bumpers that need repainted!
The Pcm is currently lying on the passenger side floor because I haven't decided how I want to mount it.
The Vette-aid Cluster is in place but not screwed in only because I haven't been able to figure out how to wire the Tachometer, however the wire were built into the New custom harness. I just don't have time to finish and complete the car BUT, All parts are there and included!!!!!!
The 4L60E transmission was completely rebuilt but not enough to handle the torque so it took out third gear. Although the car still drives, the tranny will have to be gone over!
It needs Alignment needs done and Two New front tires
The Car is Located in Erie, Pennsylvania, Buyer Will be 100% responsible for shipping! The Title is being held by my bank because they needed collateral for a loan that I took out. The Title is Clean and the car has about 127,000 Original miles.
Here is a short list of parts that were used in the build:
PARTS THAT WERE USED!
(1) 12564257 Left Fuel Rail Sight Shield
(1) 12564258 Right Fuel Rail Sight Shield
(2) 19178930 Oxygen Sensor (AC Delco AFS75) [Heated O2 Sensor] Rectangular, Four pin, 4 wire connector]
(1) LOKAR TD-34L60EFM36 Braided Stainless Steel Transmission Dipstick
(1) VettAid’s Phantom (6 Gauge) Cluster Assy. $789.00
(1) 14089936 - Fuel Pump Relay
(1) 14089936 - Fan Relay
(1) 14089936 - A\C Relay
(1) 25163473 (AC Delco EP381) Fuel Pump
(1) 25055455 (AC Delco TS1) Fuel Strainer
(1) 55816 (GM 14048936) Corvette Gas Tank 1984-1996 $249.99 (Eckler's Corvette)
(1) A8348 (GM 3849610) Corvette Gas Tank Filler Neck Drain Housing Nipple 1963-1996 $4.99 (Eckler's Corvette)
(1) 31768 (GM 14076115) Corvette Gas Tank Filler Neck Seal 1984-1996 $31.99 (Eckler's Corvette)
(1) 41483 (GM 14044556) Corvette Gas Sender To Tank Mounting Bolt Kit 1984-1996 $6.99 (Eckler's Corvette)
(1) 24210683 Used 4L60E Tranny 1998 G Van
(1) 24201517 700-R4 Transmission Tailshaft (Fits 1984-96 Corvettes only) (Used) $85.00 (Vette2Vette Salvage 1/27/12)
(2) 8637742 Tranny Inverted Flare Fitting
(1) 24232236 Band
(2) 24210766 Plate
(5) 24232517 Plate
(5) 24216946 Plate
(1) 24208576 Transmission Filter Kit
(1) 24229422 Nuetral Safety Switch
(1) 24232325 Transmission RR Output Ext. Seal (Booted)
(1) 24232617 (ACDelco #213-194) Vehicle Speed Sensor 1996 Corvette Automatic Tranny (M30)
(1) 51-0405 4L60E Transmission Adapter (From Advance Adapters)
(2) 716079 22mm Plugs (From Advance Adapters)
(4) 720028 S.H.C.S. 10mm-1.5 x 35mm Bolts (From Advance Adapters)
(1) RUS-640940 - 6AN Fuel Filter Adapter Pipe Fitting Summit Racing
(2) RUS-640850 EFI To - 6 AN Fitting To Fuel Filter Summit Racing
(1) RUS-640860 Fuel Rail To - 6AN Summit Racing
(1) 12561211 Cam Shaft Sensor (Included with engine assy PART# 12457705)
(1) 499111 - Fragola Performance 90 Degree Male -10 AN to Male 3/8 in. NPT Fitting
(1) Straight Thermostat Housing with Thermostat (Street & Performance)
(1) 499108 Fragola 90 Degree Male -8 AN to Male 3/8 in. NPT (Waterpump)
(1) 499110 Fragola 90 Degree Male -10 AN to Male 1/2 in. NPT (Waterpump)
(1) 12551587 Y-Body Oil Pan Side Cover (Drilled For Sensor)
(1) Auto Meter 2259 - Oil Temperature Sending Unit (Oil Pan) Summit Racing
(1) 12611384 Oil Pan Side Cover Gasket
(1) 89017524 PF48 Oil Filter (For use with F-Body pan w\o Cooler Adapter)
(1) LS1, LS6, LS3, LSX, Chrome Oil Pan Level Sensor Plug (https://www.alpermotorsports.com)
(1) 15260805 Accelerator Pedal 6-Speed M/Trans (M12) (Fits Cadillac CTS 2004-2005)
(1) C4-ERODP001 - EROD C4 Corvette Accelerator Pedal Bracket http://www.vetteworksonline.com/cata...roducts_id=250
(1) 12635649 Harmonic Balancer
(1) 12557840 Crank Pulley Bolt
(1) 12558253 F-Body Windage Tray (1998-2002 LS1)
(1) 12628771 F-Body Oil Pan (1993-2002 Camaro & Firebird & 2003-2014 Express G Van 4.8C Engine)
(1) 12558251 F-Body Oil Pump Screen (1998-2002 LS1)
(1) 12457705 LM7 Engine
(1) Auto Meter 2259 - Water Temperature Sending Unit Summit Racing
(1) Auto Meter 2277 - Adapter Fitting 1/8 in. NPT Female, 12mm x 1.5 Male Summit Racing
(10) 11515756 Crank Sensor & Cam Sensor Bolt (Included with engine assy PART# 12457705)
(1) 12601822 Knock Sensor Wire Harness
(1) 12608814 Engine Coolant Temp Sensor (2 Pin) (Delco)19236568 (ACDelco #213-4514) (Included with engine assy PART# 12457705)
(2) 12589867 Knock Sensor
(1) 12560228 Crank Shaft Sensor (Included with Engine Assy PART# 12457705)
(1) 12559505 Oil Fill Tube
(1) 89018052 Water Pump
(6) 12551926 Water Pump Bolts
(4) 11588714 Air Bleed Cover Bolt
(2) 12561089 Engine Cooling Air Bleed Pipe Stud
(2) 12602540 Air Bleed Cover
(1) 12577268 Mobile 1 Oil Cap (Corvette)
(1) 12602544 Engine Cooling Air Bleed Pipe
(1) 12614970 Map Sensor (Came with used Throttlebody)
(1) 17113566 TPS Sensor (Came with used Throttlebody)
(8) 12554679 Fuel Injector Retainers
(8) 0-280-155-831 Bosch Injectors 28lb/hr @ 58psi (Used from Ebay) 1/28/12
(2) 12557340 PCV Valve Pipe Retainer
(1) 12590632 PCV Pipe
(1) 12561858 Fuel Rail (Used)
(1) 17113669 Throttle Body (Used) (2000-2004 Corvette) $112.00
(1) 12560384 Right Fuel Rail Bracket (90 Degree "S" Type Bracket)
(1) 12556074 Left Fuel Rail Bracket (On Intake Manifold)
(3) 11588714 Throttle Body Bolt HFH, M6X1X30, 22.7 THD, 14.2 OD, 8.8
(4) 12554211 Fuel Rail Stud
(1) 12583628 Throttlebody (LS1) Label
(1) 19245405 TAC Module (Fits 1997-2004 Corvette)
(1) 12200411 PCM (2001 Corvette) (EFI Connection, Mike Noonan)
(1) 100-00645 TAC to Pedal Harness (CTS-V) (EFI Connection, Mike Noonan)
(8) 12621258 Spark Plug (Gap 0.040) (ACDelco #41-110) (Iridium)
(2) 165006ERL -6 AN Male to 3/8 in. Fuel Sending Unit Tube Adapter
(2) 165056ERL -6 AN Male to 5/16 in. Fuel Sending Unit Tube Adapter
(1) Set LSX C4 Motor Adapter Plates (Ordered From VettAid) (770) 464-9466 10/23/11 $96.00
(1)12568996 Idler Belt Pulley 50NM Torque to 37 FT-LB
(1) 24208649 Torque Converter
(2) 17984499 Motor Mounts (1985-1991 CORVETTE)
(1) 11610787 Starter Bolt
(1) 12561848 Starter Bolt
(1) 12602448 Automatic Flexplate
(8) 11515767 Transmission Bellhousing Bolt (M10X1.5X35) (8 Required Per Vehicle)
(3) 11589040 Torque Converter Bolt
(6) 11569956 Flexplate Bolts
(1) 88864474 Starter (ACDelco #336-1922A) (Reman) (Nu Way)
(1) 19239926 (Delco GF822) C5/C6 Fuel Filter/Regulator Assembly
(8) 12558693 Ignition Coil (Stamped 12558693) (Mitsubishi) (ACDelco #D581) (Truck) (Used) (In Place of 12558948 C5 Corvette) (ACDelco #D580) (2001-2004)
(2) 12601824 Ignition Side Coil Wire Harness (ACDelco #356G) (1999-2006 Truck) (Used) (In Place of (12582190 C5 Corvette Ignition Side Coil Wire)
(2) 12569188 Ignition Coil Bracket (1999-2006 Truck) (Used) (In Place of 12563288 C5 Corvette Ignition Coil Bracket)
(10) 12554211 Ignition Coil Bracket Stud
(1) 19147475 P/S Pressure Hose (ACDelco #36-363180) (Fits 1998-2004 Corvette) (Ordered 2)
(1) 11561025 Oil Level Tube Bolt (M6X1X16, 13.5 THD) (UNI-PACK 10)
(1) 12551577 F-Body Oil Level Tube (1998-2002 LS1)
(1) K10143 Kwik Performance LS1 A\C Compressor Bracket (http://www.kwikperf.com/lsx_ac.html) $195.00
(1) 24261714 LH Transmission Cover (ACDelco #24261714) Used on 98-2002 F-Body
(10) 12552344 Intake Manifold Bolt
(1) 12552542 Throttlebody Gasket Seal
(1) MS 92438 Fel-Pro Intake Manifold Gaskets (With Foam Under Seals)
(1) Gates 22080 Dayco 71704, NAPA 8761, OR Goodyear 62056 Upper Radiator Hose (fits 96 Cadillac Coupe Deville) (Original GM Part# 25700766) 1 1/4 or 1.25 i.d. Autozone $18.01
(1) 10271555 (1998-2001 Camaro) Lower Radiator Hose Gates 22354 NAPA 8987 ( 12/09/11)
(1) LS1 Steam Vent Tee (Ordered 12/16/11) From Jags That Run $33.00
(1) 12594779 PCV Tube (Dirty Air) ("U" Shaped)
(1) 12556454 PCV Tube (From Right Side Valve Cover)
(1) 8136 - Spectre Performance Air Filter (Blue)
(1) 95990 - Air Intake Tube, 90 degree Elbow
(1) 9776 - 4 in. Tubing Coupler, Blue, Straight
(1) 9746 - 4 in. Dia. Intake Tube To 3.5 in. Dia Air Intake Tube Coupler
(1) 15904068 MAF Sensor (2001 Corvette) ($118.72 Nuway)
(1) 4061005 Goodyear Gatorback Belt, K061005 Gates Belt), (NAPA 25-K061005), (GM# 88986813) (DELCO 6K1005)
(8) 15336959 Spark Plug Wire Shield
(1) 88894394 Spark Plug Wire Kit (1999-2006 Trucks)
(1) ATM-2241 - Oil Pressure Sending Unit (Auto Meter)
(1) ATM-2268 - Oil Pressure Sending 16MM Adapter (Auto Meter)
(2) SUM-220703 Twist-Tite Swivel Hose End Straight, -10 AN Hose Barb to Female -10 AN
(2) SUM-220758 Twist-Tite Swivel Nipple Twist-Tite Male -10 AN to -10 AN Hose Barb
(1) SUM-220789 Twist-Tite, Rubber, Blue, -10 AN
(2) 22527475 (1985) ECM Bracket Screws
(12) 11518860 Exhaust Manifold Bolts
(1) 12568181 Belt Tensioner
12544.jpg188238_196093093781569_8105744_n.jpgIMG_0240.JPGIMG_0241.jpgIMG_0243.jpgIMG_0244.jpgIMG_0247.jpgIMG_0249.JPG
