maxrevs85
My car has been up for the winter for about 1 month . Today Iwas going to out put fresh oil in it and run for a couple of minutes . And then drain it to flush out any fuel from a fuel rich problem I had previouly. I posted this in my 85 engine project.
Ok before I did this I opened the drain on the oil pan to make sure there was no more oil in it. (Previously drained). When I pulled the bolt out , about 3Qts of raw fuel poored out. Now, the car has been sitting. How could the fuel siphon out of the tank and where is entering the engine.Bad diaphram in the regulater or an open injector . I do suspect a injector being stuck open contirbuting to my fuel in the oil prob . Can it siphon thru an injector or a leaking regulator?;help
I'm going out right now to start disassembly.
