Fuel injection fuel lines suggestions?
Wilkinshc
New Mexico
1965 Coupe
Does anyone have pictures or suggestion what would be the best route for the fuel lines for fuel injection? I am going to run a rock valley gas tank.
thanks for any help or suggestions
Chuck
Chuck,
I used the original 3/8 supply line and amazingly was able to shove my 5/16 return line down the top of the frame beside the feed. It has resided up there captured for a year now. Worked for me. It would be nicer if the body was off the frame but its not. What kind of F.I. are you installing?
Frank.
I'm installing a ZL1 ram jet. I was figuring to run a line in the stock place but wasn't sure on the return line. I would like to run a second line next to it but I wasn't sure how to run it thru the frame in the rear. I have the body off but can't remember how much room there was where the stock line goes into the frame. The frame is indented there but the indent does not have enough room for a second line plus I would need to drill two hole, one going in and one in the rear which is also indent and not enough room for the second line.
Thanks for the advice.
