Mid THROTTLE RESPONSIVENESS
would probably be a more correct term in this case, sorry...
Basically, at Full Throttle, or Wide Open Throttle, carbs and FI perform indistinguishably. Both deliver power based upon the maximum amount of air that the "throat" can pull in past it - they will each measure out the appropriate amount of fuel to accomplish this.
This can occur at any given speed or engine speed. It's the steps in between (as idle is more a utility thing that works well in either also) where it's easier to get FI to accurately deliver the appropriate amount of fuel to the air your engine is calling for based on where the throttle cable opened the butterfly to.
In fact, carburetion really only "works" exactly in a fully-controlled fashion at as little as two places: at idle and at wide open throttle. Some add a mid point or two where the fuel is precisely measured also, but most carbs rely on the "fudge" of squirting some fuel in the otherwise carefully measured fuel to speed up the transition from idle to wide open throttle - or to go to somewhere in between and function powerfully and not too wastefully. Incidentally, multi-barrelled carbs often double these "fully controlled" points. That squirting is acomplished by using an "accelerator pump," which also might be multipled.
Fuel Injection can even go one better and gets the fuel in there
before the engine vacuum sucks in the fuel that would normally be measured by the carburetor's fuel metering circuits.
This makes FI
generally capable of faster, more appropriate responses to changes, other than the extremes of just flooring the pedal or dropping it off. It also makes it less dependant upon engine vacuum for accurate functioning, and thus much more immune to odd vacuum leaks than carburetion.
(This latter advantage is
way, way offset by its disadvantage due to the potential of errors to sensor damage or electrical shorts, low system voltage and so forth, which does little to a carburetor.)
Oh, BTW, I agree with DarkShark78 - on
one point. Old carbs
SUCK!!! I would only get a new one out of the box!
But you can get a new Edelbrock Performer Carter AFB-clone or a
Demon improved-Holley, with all the common bolt-on improvements for $300-400 or an upgraded Holley for $500.
My carbs don't
leak! Tune with a
screwdriver, fuelie-boy!!! :L
Oh, one more thing, FI-freaks are always on about their cars starting after leaving them parked in a center of an iceburg since the last mastadon used the last carburetor without doing anything more than reaching in the window and twisting the key when it's 4 degrees above absolute zero. "Carbs can't do that."
Please.
Living in a civilized part of the country without ice all the time, :t I can't claim lots of experience with the more extreme tests of this.
Yesterday morning though, I got in the car at 5AM when it was 23-25 degrees, unusually cold for this brightest part of the best part of America.
I got my substantial proportions in the driver seat, somewhat nimbly I may add, did
not even touch the gas pedal and turned the key. I'm running 35 degrees total advance, 11 of it mechanical. New Edelbrock 750 Performer - manual choke with the choke wired full open. I need to install my new Holley mechanical fuel pump because the stock one fuel starves it on a full throttle launch from start after I hit about 5200 or so unless I let off on it for a second.
It started within a second after sitting there for ten hours.
Carburetion won't start in the cold. Pfft.
I do like FI - and will probably go that way eventually - on the ultimate engine. Carbs, however, work fine, especially the ones out in the last five years, and especially if you don't try to cobble a busted up one together or make an improperly chosen one do on your application.
