Adding EFI to a Chevy will be the easiest EFI and least expensive conversion you could possibly do. (The big block is a little more difficult if you want to use junkyard parts but still doable)
I am a MOPAR man and there is NOTHING available unless you have a $3000 budget.
That being said it is still A LOT of WORK.
Here is a short list of what you have to do.
- Change fuel pump efi needs an electric pump and higher pressue
- replace intake with TPI setup or modify existing intake to accept fuel rails and fuel injectors
- wiring harness
- computer and proper programing
- o2 sensor added to exhaust
The simplest was is to get a complete TPI setup from a swap meet, e-bay or junkyard. There are a few companies that make wiring harnesses for this conversion. You couls use a GM computer but i would like something user programmable like the MegaSquirt, it think holley and accel also make something.
Check our the megasquirt link in the other post there is a lot of good info, tips adn links there. Also there are several booke out on how to do the conversion, your library may have them or look in the automotive section ar Boarders or B&N.
For a first attempt I see a lot of complete holley projection setups on e-bay for a good price. There are Throttle body setups, not the best, but still better than a carb. there may be a reason people are selling them but I think they work better than a carb when properly installed
Scott
