MaineShark
- Joined
- Sep 21, 2002
- Messages
- 1,326
- Location
- Rockingham County, NH
- Corvette
- 1979 L82, 1987 Buick Grand National
And odd thing that I read from some guys having an online discussion about superchargers, and whether to run a carb or EFI. The claim was made that the wet flow of a carb (or TBI) will help cool the charge more than the dry flow of a multi-point system. Basically, if I follow the details correctly, the wet flow allows more time for the fuel to evaporate, reducing the temperature of the charge air. Obviously, the gross heat (thermodynamics here) of the charge will remain constant, but that heat is not evenly distributed, so I think the idea is that the fuel will have more time to atomize, and will spend more time in contact with the air, so that greater heat transfer will take place between the fuel droplets and the air.
A couple issues with this. First, in order for it to work out, physically, it requires that the fuel be lower temperature than the air. I've never measured fuel temp or inlet air temp, so I don't know if this is the case. Second, even if it were the case in a supercharged system (hotter-than-normal air temp), would it still be the case in a naturally-aspirated system?
Thoughts?
Joe
Thoughts?
Joe
