D
dunagan
I have a 1967 427/400 w/ a fuel leak apparently at the connection of the fuel line to the carb. Which nut is the culprit? THe large nut appears to have a washer and the small nut secures the flared end of the line. Is there a "special" trick to keep this connection dry? Any tricks to the tightening routine?
I have heard this was a common problem. Is there anything that can be applied to the nut to seal it?
I have checked the nuts and both are EXTREMELY tight so there does not appear to be a loose connection.
Thanks for any suggestions.
