Fuel line connection problem
  • Thread starter Thread starter sumoboy
S
sumoboy
I just found out that the braided pressure line to the fuel rail has been rigged with a rubber fuel line. It's not leaking and was covered up pretty good with wire loom, looked almost factory. I don't know if the previous owner damaged the connection at the ends from the braided line to the metal line to the fuel rail. I have a feeling he never used the right tool to remove the line. Is it repairable? (The connector on the braided line). It got too cold to really check it out tonight but will look closer tomorrow. What a bummer. I have to get tags for it yet, bad weather since I bought it in Jan. :(
The line on the right should be connected to the one in the middle
