corvette66
Hello all. I have a couple questions for ya. Does anyone know how many lbs psi thoes c4 in-tank pumps put out? I know that mechanical pumps are around 7.5 psi. EFI pumps are around 28-40 psi, i think. I'm still working on this Big Block C4. Now I am deciding what to do with the fuel pump situation. The pump that is on the car is to powerful for the carburetors i would assume. So I wonder if I could use the stock pump with a fuel regulator to cut down the psi. ???????
Question for a buddy of mine..... anyone know the specs on an 1985 C4 cam shaft? (duration and lift) Also would any SB-chevy cam work as a replacement? Obviously the tourque and Hp range would change, but would any performance cam work with his stock equipment?
