Nick0187
New member
So I bought an 86 vett that's a bit of a project. Im not getting power to the fuel pump...again. I will start from the beginning, I had an intermittent crank issue so I bypassed the starter enable relay by cutting the two wires and splicing them together and now it will crank just fine. I got it to run with good fuel pressure. I also had intermittent LCD screen issues so I went ahead and replaced every single fuse in the fuse panel and now the LCD screen works but the fuel pump won't turn on. I get power to the FP fuse for 2 seconds after turning the key as well as when I crank the engine. I replaced the entire fuel sending unit including a new fuel pump because it was shot and rusty. I have tried applying power to the G terminal of the ALDL with no luck as well. I am getting a signal for the fuel level, not sure what that means though..lol. I just use a light tester on the red wire at the fuel pump connector and ground it to a bolt on the fuel filter lid to test it and it seems like il
getting no power to the fuel pump. Looking at a wiring diagram, it looks like the power wire from the fuse goes straight to the fuel pump, although it is different colored. Any ideas?
FYI: I'm no mechanic, but pretty handy and get do most tests with the tools I have, so if I sound like an idiot, bare with me..lol
