playsdixie
weird one....was going to tear down the engine on my 85 and rebuild...decided to take one last run....car started/idled/ but wouldnt go.....threw a code 34....maf....did some diagnostics couldn't get the maf wire to glow with test leads...determined burn off probably bad....BUT....also threw the fuel guage on,,,,o pressure with key on, 20 # after start up...idles /won't drive....did further diagnostics....the fuel pump will turn on with 12 v to the fuel pump test lead...but still only 20#...fsm doesn't cover this issure....how come the pump works but wont come on with the key???....is something in the maf/burnoff circuit affecting this??? why only 20#...fuel pump is new...2 months old...:ugh
