I just did mine last weekend on my '77--should be pretty much the same.
First, get your fuel tank as empty as possible--all the remaining gas will come out with vigor--don't think you can swap the hoses fast enough.
Second, the hoses look hard to get to, but they come off very easy and it really is pretty straight forward--after I did it I wondered why I put it off so long.
Third, once you get the rubber hoses off the pump, everything else is easy to get to on the pump.
Forth, I read somewhere that if you coated the fuel pump rod with grease, and stuck it in the freezer for a bit, it stays in place while you position the pump. I tried it and it worked.
All in all, about an easy hour's job.
