I can't figure out how to get the fuel pump reinstalled!!!! I search the archives and read the advice on past posts regarding this but I can't manage to get it to slide in and install. I turned the motor over to TDC on the #1 cylinder to have the rod on the proper spot on the cam's lobe, put a longer bolt in the hole in the engine block, but the pump won't slide in. in fact as I would turn the motor over I'm not even seeing the rod move at all as the lobe of the cam goes around as I expected to see.
should the rod be easily moved up and down by my finger? I reached in there to try to lift it up but it won't move at all and it feels very tight almost like it's jammed in there against something and has no play or movement up or down or sideways. Is it supposed to be loose enough I can move it with my finger because it's not.
Any help would be appreciated.
Thanks!
Thanks!
