fuel pump sock
9
92conv
Hey all, what is the down side of installing a fuel pump without a sock on it? Obviously, it would suck up all the built up crap sitting on the bottom of the tank but is there anything else i.e. burning richer due to less constricted fuel flow or something like that? Thanks guys. Corvettes rock :_rock
c4c5specialist
Technical Advisor
New Haven, Ct. USA
Nope, but someday.
HI there,
The sock filters major contaminants and absorbs water.
Fuel filters normallly filter to 15 microns and the sock about 30 microns.
It does NOT restrict fuel flow.
Allthebest, c4c5
9
92conv
C4C5, When I checked out my fuel sock it turned to powder in my hand. Now if that s*** has been getting sucked in to my engine ( :mad ) I think it would be better to keep it topped off and leave the pump open and just replace inline fuel filter as necessary. Maybe not but that sock dust was not too cool to find!
wishuwerehere82
Rochester, NY
Red '82 Coupe,Sebring Silver '98 Coupe
You need protection of some kind to keep stuff out of the pump itself.
That is the main job of the sock. If a chunk of stuff gets into the gears of the pump it's going to do some serious damage or stop the pump dead in its tracks.
c4c5specialist
Technical Advisor
New Haven, Ct. USA
Nope, but someday.
HI there,
Totally agree with that one.
Usually, if your sock degrades, that will show that some type of contamination had entered the fuel system to do that to the sock.
Simply replacing it and allowing the system to run as designed and being careful of what fuels are used and NO additives other then maybe a Techron occasionally should be all you need.
Allthebest, c4c5
John Robinson
Gone but not forgotten
Muncie, Indiana
1993 Polo Green Coupe
GM did not put that sock in there just to run up the cost of the car. It must meet a specific engineering need or it would not be there.;)
D
D.O.Dug
c4c5 & John R. are right. Crap gets in your tank no matter what you do. Contamination from old gas station tanks, water that can form rust, etc. etc.
Do yourself a favor - you've already got the pump out. Replace the sock. Then you know it's done right. :upthumbs
