Fuses
  • Thread starter Thread starter ND67
N
ND67
Hey Guys,
This weekend I noticed that many of the fuses in my fusebox are wrong. The owner before me seems to have added a 20amp fuse each time one blew. Now all but two are 20amp.
Everything seems to work fine so I didn't worry about it. Can this do any damage?
Thanks,
ND67
Fuses are intended to protect the devices on the circuit... their purpose is to sacrifice themselves to prevent serious damage when a device malfunctions (shorts) internally, or fire when there is an electrical short in a wire run.
On a 15 amp circuit, everything downstream should be capable of withstanding just a little more than 15 amps without being damaged, but should normally get/use much less than 15 amps. 15 amps is abnormal for the combined load of all devices on the circuit, forcing the sacrifice of the fuse (better to blow a 50 cent fuse than ruin a $100 heater motor).
So, as long as nothing goes wrong, the 20 amp fuses just conduct normal current load.
It's kinda like asking if a glass of water will suffice as a fire extinguisher... it all depends on whether you ever have a fire, and if so, how big it is.
Were it me, I'd change the fuses back to the book values.
