fx3 suspension
T
Tim46
My 95 convertible with selective ride control has the "service ride control"light on. I checked and found the front right shocks gear that fits into the actuator broken. Do I buy a new gear or shock? And once I repair this will the light go out?
S
Steel Half-Shafts
Tim46,
I pretty sure you can't get the gear separately without buying the whole Shock/Actuator assembly from GM. :(
But, here's a great link that shows how to repair the failed gear.
FX3 Gear Repair
Once you replace or repair it, you will need to clear the Trouble Codes to get the "service ride control" light to go out.
The Service Manual will give you the info you need to do this! :eyerole
Rabbit
sonoma ca usa
2004 C5 coupe, MSGM & 2014 Cad SRX Crystal red
Try contacting Bilstein in San Diego at 800 537-1085. Ask for BillHindorf. He shud be able to advise you re: rebuilding.
T
Tim46
Thanks - I called Bilstein and they can rebuild the shock with the gear for $100. Tim.
