I live in eastern canada,It seem humourous to me to hear you guys not really knowing what to use for heat. around here , if you dont have heat, you have cold,very very cold.brrrrr.you could hang meat to cure.even if the garage is heated while your there,the concrete never gets warm.you still need cardboard to lay on the floor.
I am building a new garage now, it will be 24x28 with a 10x12 tool /furnace room on the side.
we dont have natural gas(propane only) electric heat is cost prohibitive,so oil is the way to go (wood is slow and messy).
hot air oil will blow dust around ,so you cant paint with it.
my solution is in floor radiant heat.you take an oil fired domestic hot water heater(direct vent),a thermostat, a circulating pump,and i have installed 500 feet of 1/2" high pressure plastic tubing wired to the steel mat under the concrete.
this set up is ideal for any garage /paint shop.
with the oil tank outside , the furnace in total only takes up about three feet square.the floor is warm and is great to melt ice and snow off the bottom of the car.the water on the floor dries quickly.and best of all there is no airborne dust being circulated around the fresh paint.
I have spent conciderable time researching this,and its the best solution i can find for my needs,and probably many others.
someone spoke of propane,this must be vented outside,and only the heat circulated inside, as propane produces vast amounts of moisture as a result of the really clean burn.it doesnt produce hydrocarbons like oil,but it does produce water and carbon dioxide.this will surely be detromental to any metal inside the garage.
sorry for the verbal diarhea,but you spoke of what i am interested. mike. hope this info is usefull.
