S
smorrismi
Here's the history: I had to restore the gas tank because it was filled with rust. Got the gas tank in (it leaked the first time so I'm an "expert" at installing now LOL), hooked everything up, new sending unit, blew lines out both ways (gas tank "in" to fuel filter "out") to be sure it was indeed open and not corroded anywhere throughout the line. Came out gummy but ok. Plus I didn't want anything debris going into my carb...even with the filter on. Here's where the trouble starts. I took off the distributor, no need for spark and gas, removed the line from carb and put a plastic bottle over the fuel line and tried turning over the engine until I got gas in the bottle. I've gotten nothing. I've been turning the engine over until I have to recharge the battery... had to do this about 3 times now. Then I took off the line to the filter and rigged another line into the bottle from there. Still nothing.
My real question is, do I need to prime the pump or something? Pour gas down the opposite way to create some vacuum? Any suggestions would help. :confused
