andrewc4
94 - Gasoline drips while I'm disconnecting/connecting the inlet hose on the new fuel filter, (ACDelco). The line comes from the gas tank, and is probably lower than the tank, directly connected, so the fluid drips from the any available hole, in this case the open inlet pipe.
Is there a way to prevent this drip? Its messy and its dangerous.
Should I have changed the filter with only half a tank? Too late now.
By the way, the previous owner had a Fram fuel filter installed. Are the fuel filters as bad as some say the air filters are?
