I love mine....but, then again, I'm a gauge NERD!
(God I hate Earthlink....20 mins writing a reply and it goes offline to save bandwidth...when it's so slow I can't even d/l movies....which of course lost all my pending post
except the title! I need to get a new cheapy ISP like Netscape and fire them TODAY! I won't even mention the "spam only" email service...)
ANYHOW....
I have not only the red Nordskog main and auxillary panel, but during my monster dash/HV (not "AC" yet!
)/radio upgrade that took it down for almost 3 months..second longest down time for an improvement yet...I also made an auxillary dash top gauge panel out of fiberglass (padded and covered like the dash) that holds
another eight digital gauges. (Some are Nordskog also, but the vacuum/boost, fuel pressure and A/F meters are cyberdyne and ultralights.)
These things are GREAT! They are perfectly visible in all lights (the other colors aren't, sadly) and, despite what some bastards at work like to ridicule as the "Kitt the Junker Car" look, they are maybe the single most gratifying aesthetic aspect of the whole project so far.
I have had an intermittent problem with the high beam indicator and the headlight door opener thingy has never worked right, but neither fault is due to the gauges but the switches or wiring.
By the way the installation of the Nordskog panel is anything but "drop in." Not only is there extensive wiring, which I have always actually enjoyed because I'm just not 'right', but you actually have to take a dremel to the main circuit boards like they are a cheap rifle in the hands of a kitchen table "gunsmith". The gauge holder bodies in the car are usually broken somewhat, so your epoxy skills are quickly improved as well. Putting the gauges in and out without breaking up the newly repaired ones is not light weight stuff either.
I love the appearance of mine enough I will alter other vehicles to have digitals now.
If I wasn't so dim I'd take a pic and post it - although power's off until the engine goes in, but again, I'm not sharp enough to do that.
I recommend it, but be careful - it's pricey and very involved and takes a surprising amount of time to do it. You'll want to replace all that ancient wiring and vacuum tubage and fix the disconnected and leaky heating vents while you're down there. It is a big undertaking.
BTW, I welded in a fitting on my new Moroso 7 qt pan for the oil temp sensor and just replaced the diffy drain plug for that temp sensor, but my tranny guy talked me out of doing something similar to the generally thin tranny pan and instead drilled and tapped a hole in the main valve body case on the T400 for less chance of leakage.
