Hrtbeat1
I have several old blocks and heads laying around and have been thinkking of doing something with at least some of them. The blocks are all old two bolt main 350's, the heads are from an old chevy truck ('79 165HP?) plus a set from an old Impala (70?). I also have a set of old Chevy Double Hump heads that I paid like 6 bills for YEARS ago. These are not the 2.02/ 1.60 but the 1.94/1.50 versions ... not sure of the casting numbers, I'm thinking they are the 461's and not the more desirable 492's. I will check tommorrow cos now I'm curious.
Anyway I was looking thru some old info I had printed out and I found some flow numbers that had the double hump heads and the "new" Gen II LT-1 heads looking almost identical. No mention of casting numbers which I know can vary greatly. I tried to pull up the site but it no longer existed.
So here's my thought ... take the double hump heads with a crate aluminum short block a modified LT-1 intake and all the necessary wiring/computer/harnesses. What would you're thoughts be on this combination? The doublehump heads were using a carb, but were good to around 6K right about the area that the LT-1 intake shows improvements over the TPI intake. What would be a guesstimate as to TQ/ HP numbers?
I wanted to use this head for a build up of a '79 K-5 Blazer (383, possible FI) but realized I would be better off with low end torque vs. top end HP in this application, so the heads have been sitting on the shelf since (way too many years). BTW the K5 is still sitting waiting for a heart.:duh
Any thoughts would be appreciated. Thanks.
