Gear Ratio Change From 2:73 to ?
  • Thread starter Thread starter Rock Doc
R
Rock Doc
Next week I am going to change my 2:73 gear to 3:? gear. Right now my 2003 Coupe is bone stock. Any recommendations from the experts will be appreciated.
Thanks Rock Doc (Kevin) :)
Kevin,
I have the same rear end ratio in my 04 and was thinking about the change to a 3:40 (?). My previous 01 convertible had the performance ratio and I was very pleased. Please keep the board posted as to costs, computer re-programing, etc.
Keep the wave.
Larry
Yank 3500 1.6 str convertor ~900
3.73 gears 1000
LS1edit and installation required: 1000
If you don't mind a suggestion...at this point and time I would suggest saving your money and plan to do an 8 thousand dollar Intercooled magnasum supercharger installation and keeping your stock gearing..
You could probably get the non intercooled version and have it installed for a grand less?
For 200 dollars you get a 36month/36 K mile full drivetrain warranty with the magnusum..
That would be what I would suggest..
Leave the gears and the convertor alone...
Go with a supercharger and get the extended warranty too boot!
Good luck in whatever you decide.
