Gearbox identification
  • Thread starter Thread starter insiswe
I
insiswe
What gearbox is this.The taihousing has a Borg Warner badge.
The number onthe box is 13 04 066 903.and WK2682.Please advise
Thanyou very much for the information.I will check what you have asked and revert.THANKS AGAIN FOR SUCH A PROMPT REPLY.
If the main case casting number is 13 04 065 (not 066) 903, it's a 1979 model year (October 1978 build) B-W Super T-10; should also show the following casting numbers:
Tailhousing: 13 04 066 901
Side Cover: 13 04 097 901
Rear Bearing Retainer: T89C-6A
The OEM Corvette version of the Super T-10 had an additional 2-digit code painted on the main case, just below the side cover, to identify the 1st gear ratio. HS = 2.64:1, HW = 2.43:1.
Thanks to all for your input.
This is what Ihave found after your information.
Tail housing:Aluminum- number 13-04-066-903
Gearbox;Aluminum-13-04-065-903 /WGDW/Fpc-3
gearbox elsewhere;MLT7802/10.6.78/2 29W116672
Gearbox cover;C 11 78 /Q5/ 13-04-097-901
It has 26 splines with 3 grooves.
If this is a super T10 could it be original to this 1978 silver anniversary?i.e Where M20's standard for this car.
Thanks again for your input.
The main case and side cover are the same as the Super T-10 used in the Corvette, but the tailhousing is from another application; the Corvette tailhousing ended in -901 from '74-'78, and in -905 from '79-'81; don't know what application used the -903.
The latest Colvin charts show the codes below the side cover identifying the ratio differences - they may be in error.
