S
studiog
Hi all,
I just test started my rebuilt 283 motor- 2x4 270HP. It is mounted on my rolling chassis. Expected a few problems and had a few problems.
1) The back carb is loading up and dumping excess fuel into the manifold.
2) Oil leak from a plug in the block just above #7 cylinder and to the right. I think I will have to pull the head to get at it as it is half covered by the head. (Not happy with my machine shop right now)
3) The generator is running hot. It is not hooked up to anything just there so I can run the belt to the water pump. Do I need to ground it or something, or is it OK to run like that?
Aside from that It ran and sounds awesome.
Thanks for any replies.
